Hi
I need to install Thingworx 9.2 on a server for Postgress sql.
In between Thingworx Installer and Manual installation,
I need suggestions on which is the better option. And what are the differences between them in terms of platform stability, performance, and maintenance.
Thanks and regards.
Difference between ThingWorx installer and manual installation is explained in this post.
Setting up Thingworx with installer is much easier and takes lesser time. From stability and performance standpoint there is no difference.
Sachin Sharma
