Where to find the expression display name ?
  • August 19, 2019
  • 2206 views
The expression and validation become  a setting in the Function panel since 8.4.  However the debug info only display the display name of expression/validation , like UIexpression-59  instead of the name I created for expression/validation.
Where can I find the display name ?
Sean
Best answer by slangley
Hi @seanccc.
ThingWorx 9.0 was released yesterday, and it contains the fix needed to expose the expression system ID.  Since we now have a fix for this issue, please mark the appropriate post as the Accepted Solution for the benefit of others with the same issue.
Thank you for your participation in the community!
--Sharon
seanccc17-PeridotAuthor
The display name shows up when deleting the expression, it's only way I can find .
Community Manager
August 28, 2019
Hi @seanccc.
Apologies for the delay on this post.  We have validated this behavior and have reached out to R&D.  Once I receive a response, I will advise if this needs to be submitted as an improvement on our Ideas page or whether there is another way to see the custom name in debug.
--Sharon
Community Manager
December 27, 2019
Hi @seanccc.
Just an update.....The issue you reported regarding the Expression System ID not being exposed, is targeted for resolution in the next release of the product due out in Spring 2020.
--Sharon
