Where to find the expression display name ?
seanccc
The expression and validation become  a setting in the Function panel since 8.4.  However the debug info only display the display name of expression/validation , like UIexpression-59  instead of the name I created for expression/validation.
Where can I find the display name ?
Sean
slangley
(To:slangley)
Hi @seanccc.
ThingWorx 9.0 was released yesterday, and it contains the fix needed to expose the expression system ID.  Since we now have a fix for this issue, please mark the appropriate post as the Accepted Solution for the benefit of others with the same issue.
Thank you for your participation in the community!
Regards.
--Sharon
6 REPLIES 6
seanccc
(To:seanccc)
The display name shows up when deleting the expression, it's only way I can find .
slangley
(To:seanccc)
Hi @seanccc.
Apologies for the delay on this post.  We have validated this behavior and have reached out to R&D.  Once I receive a response, I will advise if this needs to be submitted as an improvement on our Ideas page or whether there is another way to see the custom name in debug.
Regards.
--Sharon
slangley
(To:slangley)
Hi @seanccc.
We have created an internal ticket for this issue.  Unfortunately, there isn't a workaround available.
I will post an update here once further feedback has been received.
Regards.
--Sharon
seanccc
(To:slangley)
@slangley ,
thank you for following up.
slangley
(To:seanccc)
Hi @seanccc.
Just an update.....The issue you reported regarding the Expression System ID not being exposed, is targeted for resolution in the next release of the product due out in Spring 2020.
Regards.
--Sharon
slangley
(To:slangley)
Hi @seanccc.
Regards.
--Sharon
