Why use Edge Micro Server and not Kepware with OPC UA
Hello everyone
I have made a connexion between my Raspberry Pi with sensor to the ThingWorx platform via the Edge Micro Server via a tutorial on the ThingWorx development portal. I saw also that there is an industrial standard with OPC UA and Kepware. Now i have a few questions about it:
- Why does the tutorial don't use the industrial standard? I read somewhere it is maybe because of the cycling rate but i am not shure. Where can i find information around this subject to substantiate my topic.
- Can we relate the industrial standard with OPC UA and Kepware to the OSI model with OPC UA in the application layer (layer 7) and Kepware in the transport layer (layer 4)?
Thanks for your help.
Kind regards
Jelle
