cant find connected clients in hosted server
Garnet
I'm trying to run analytics job on the hosted server and I'm not able to find connected clients on my provider
7 REPLIES 7
Re: cant find connected clients in hosted server
@mahitejg
Thank you for open this post on community.
Could you please confirm if you have successfully started the ThingPredictor agent and it is running?
1)Which version of TWX and TWA you are using?
2) ThingPredictor version?
 Regards-Mohit
hi @mgoel im using hosted server with analytics server version
8.3.040506
TW.AnalysisServices.AnalyticsServer.AnalyticsServerConnector connector
8.3 version of twx
8.3.040506
8.3 version of twx
@mahitejg
Are you trying to publish model from analytics builder? Is there any error when you are publishing the model.
I see one difference in Twx 8.2 and 8.3. 8.2 would need a connected client to get the analytics working whereas 8.3 does not bother about the connected clients what is the difference in both these theories
@mahitejg
Even in 8.3 version you can use ThingPredictor to see connected clients.
Hi @mahitejg.
If you have found a solution to your problem, please either post the solution here or mark one of the previous responses as the Accepted Solution for the benefit of others who may experience the same issue.
--Sharon
