delete file without storing in recycle bin
AP_9587236
If i used Things["SystemRepository"].DeleteFile(); service, then the file should be deleted in repository and it should not stored in recycle bin. How to do this
1 ACCEPTED SOLUTION
In my case,  deleted files using Things["SystemRepository"].DeleteFile() doesnt stored in recycle bin.
Hi @AP_9587236 ,
As I have understood from the given query is that, After deleting the file using the mentioned service from the repository and it should not go to the recycle bin. As far as i know, this cannot be done. Still, I will try to collect more info and get back to you.
Regards
Bhawna
I guess we have to change settings in recycle bin but that would affect all the files
