ems filetransfer - adding virtual dir
  • May 15, 2019
  • 2977 views
Hello everyone,
I'm a beginner in thingworx.
Right now i'm busy with adding filetransfer to my project.
I have an linux server with EMS 5.4 installed on it.
I created in thingworx a Thing with base template "RemoteThingwithtunnelsandfiletransfer".
In my config.json i have this setup:
	"restart":	"any",
	"logger":	{
		"level":	"DEBUG",
		"audit_target":	"file://home/pi/microserver/logs/wsems",
		"publish_directory":	"/home/pi/microserver/logs/wsems"
	"offline_msg_store":	{
		"enabled":	true,
		"directory":	"/home/pi/microserver/opt/thingworx",
		"max_size":	65535
	"ws_servers":	[{
			"host":	"thingworx.be",
			"port":	443
	"resource":	"/Thingworx/WS",
	"ws_connection":	{
		"encryption":	"ssl"
	"certificates":	{
		"validate":	false,
		"allow_self_signed":	true
	"appKey":	"xxxxx",
	"http_server":	{
		"host":	"0.0.0.0",
		"port":	8000,
		"ssl":	false,
		"authenticate":	false
	"auto_bind":[
		{ "name": "EEG.PoC.Edge.TestFileTransfer2" }
	"tunnel":	{
		"tick_resolution":	5,
		"buffer_size":	8192,
		"read_timeout":	50,
		"idle_timeout":	300000,
		"max_concurrent":	4
	"file": {
		"max_file_size": 8000000000,
	"virtual_dirs":[
		{ "In" : "/home/pi/microserver/in" },
		{ "Out" : "/home/pi/microserver/out" }
	"idle_timeout": 12000,
	"staging_dir" : "/home/eeg/microserver/staging"
When i start my EMS. he create a new Directory "staging". But no "in" or "out". Also if a run a service on my thing like "getDirectoryStructure" i get no data back.
In the logs of the EMS i get a info message that he succesfully created the virtual dir in the path described.
How is it possible that he doesn't create the in and out directory on my linux ? And why im a getting no data back from the service ?
What i'm a doing wrong ?
Thanks for the help !
Best answer by wposner-2
Yes.  Anytime you make changes to your config files or any underlying .lua files you must restart the applicable runtime.
Virtual directories that you specify need to exist.  The EMS will not automatically create them.  Once you're directories exist, the GetDirectoryStructure service will work
Thanks for the answer.
I added the 2 dirs to the path i specified in the config.json.
I setted the permissions of the 2 dirs to full access (chmod 777).
But still if i run the service i get no data ..
There are also some text files in the 2 dirs.
I restarted my server. Then it worked.
Thanks for the support !
