error in S.c.t.d.e.DSLProcessor
  • August 18, 2021
  • 1088 views
I am getting error origin from S.c.t.d.e.DSLProcessor. what does this error means?
Community Manager
August 18, 2021
Hi @AP_9587236
Did you mean to post the error?  Where are you seeing the error?  Please provide more details or the issue and your configuration.
Please post the full error message so we can assist.
--Sharon
In Logs tab, there is a column called "origin". There S.c.t.d.e.DSLProcessor, c.t.w.p.APIProcessor, c.t.s.s.w.p.WSExecutionInstance
error is occuring. What is the necessary steps have to be done to rectify these kind of errors.
Community Manager
September 10, 2021
Hi @AP_9587236
The origin provides where the problem is occurring but we actually need the message.  What's in the "Content" field?  What is the logging level of the message?
Also, you can pull the full logs at the o/s level.  They will be located under \ThingworxStorage\logs.
If you can provide these or a screenshot of the message you're seeing, we can take another look.
--Sharon
