how can I read value of xml node?
  • December 20, 2017
  • 4556 views
Hi all,
I want to read value of node (not attribute). I can read value of attribute clearly but I missed something. Could you please help me?
My xml file;
<?xml version="1.0" encoding="utf-8"?>
<ITEMS>
<BATCH_ID>X001</BATCH_ID>
<NAME>XML TEST VALUE </NAME>
<STEPS>
      <STEP>
           <STEP_ORDER>1</STEP_ORDER>
           <NO_MORE_THAN>1,5</NO_MORE_THAN>
           <START_TIME>1513750662</START_TIME>
      </STEP>
      <STEP>
           <STEP_ORDER>2</STEP_ORDER>
           <NO_MORE_THAN>2</NO_MORE_THAN>
      </STEP>
      <STEP>
           <STEP_ORDER>3</STEP_ORDER>
           <NO_MORE_THAN>20</NO_MORE_THAN>
      </STEP>
</STEPS>
</ITEMS>
My script code is;
var params = {
ignoreSSLErrors: true /* BOOLEAN */,
url: 'http://caws.ixcoe.com/data/pfizer.xml' /* STRING */
// result: XML
var xmlVar = Resources["ContentLoaderFunctions"].LoadXML(params);
result = xmlVar.batch_id;
Best answer by CarlesColl
I've tested without the service call and it works, should be something with the XML answer from your service:
var xml = new XML();
xml = <ITEMS>
<STEPS>
      <STEP>
      </STEP>
      <STEP>
      </STEP>
      <STEP>
      </STEP>
</STEPS>
</ITEMS>
var result = xml.BATCH_ID;
It's case sensitive
Best Regards,
Carles.
burak1-VisitorAuthor
Hi Carles,
I tried with BATCH_ID but result is same
xml = <ITEMS>
<STEPS>
      <STEP>
      </STEP>
      <STEP>
      </STEP>
      <STEP>
      </STEP>
</STEPS>
</ITEMS>
