"Value" SQL keyword giving errors.
  • August 14, 2019
  • 1419 views
Hi all,
I have a query where one of the columns I'm selected is named "Value", so in my query it appears as:
SELECT .... PM.Value
It appears as if ThingWorx/SQL is treating this as a reserved keyword of some sort, nothing I do will allow me to have the word "Value" in SELECT statement. It always fails and returns the error:
Unable to Invoke Service <ServiceName> on <ThingName> : The connection is closed.
I have tried aliasing the column name:
PM.Value [Othername]
PM.Value AS [Othername]
I have tried creating an input parameter string, setting it to "[Value]" and then putting it into my SQL statement as <<inputparam>>.
Microsoft SQL Server Management Studio handles the query completely fine, no issues at all.
Any help would be greatly appreciated.
Thanks.
Best answer by rrosenlof
Ahhh, I found out my own issue...
Turns out the data type of the "Value" column was SQL_VARIANT, I needed to CAST it as a VARCHAR in this case.
SELECT ... CAST(PM.Value AS VARCHAR) ColName
Thanks.
rrosenlof1-VisitorAuthorAnswer
Thanks.
