thingworx agent to connect to Azure IoT hub
Is it possible to connect a Thingworx agent( made by the c sdk) to send messages to Azure IoT hub. If we have to connect Thingworx agent based devices with Azure then how it should be done ?
Hi
To answer your original question, it's not possible to use our SDK to send messages directly to the Azure IoT Hub. You would need to use an SDK that talks with the Azure IoT Hub to accomplish this. As Vibhuti stated, we do have an IoT Hub connector that allows you to interact with the Azure IoT Hub, but this interaction is between ThingWorx platform (not an agent) and the Azure IoT Hub.
Regards.
--Sharon
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
