thingworx running connect error
  • January 23, 2026
  • 187 views
I am using ThingWorx Platform Release 9.2 and DatecodeSP0
thingworx plalform running come out the below error:
it's can spilt 3 phase
at first it's come out:
[SECURITY FAILURE Anonymous:@unknown -> /ExampleApplication/IntrusionDetector] Invalid input: context=HTTP header value: referer, type(HTTPHeaderValue_referer)=^.*$, input=https://bcnkmns0079.kmn.prod.cnb:8083/Thingworx/Runtime/index.html?mashup=BayerOEE_FloorSelect&twxToken=123&appKey=ed7a791e-6e50-46ba-af4b-fcc5753ede73&x-thingworx-session=true&user_id=GFWMB&user_name=陈兴梅
then come out :
Execution error in service script [getBoardRoomEquipment] :: Execute Query failed. Please check Database logs for more details.
the last :
com.mchange.v2.async.ThreadPoolAsynchronousRunner$DeadlockDetector@5d7dcbd2 -- APPARENT DEADLOCK!!! Creating emergency threads for unassigned pending tasks!
Here are the errors that I faced
Execution error in service script [getBoardRoomCleanStatus] :: Execute Query failed. Please check Database logs for more details.
Java heap space
Error trying to process message: Binding failed, see server log for more information V1BindMessage [header=V1MessageHeader [messageType=10, requestId=2037187, endpointId=0, sessionId=968908596, flags=0], gatewayName=Bayer_KEPServerEX, gatewayType=IndustrialGateway, names=[test_jarline1, Bayer_KEPServerEX, 铝管一线 Alu tube line 1, 瓶装四线, 瓶装三线 Bottle line 3, 铝管三线 Alu tube line3, test铝管一线, 瓶装一线 Jar line1, 支装三线 Plastic tube line 3, 支装一线 Plastic tube line 1, 袋装二线, 支装二线 Plastic tube line 2]]
    Hello @JH_12968901 ,
    You indicate that you are using ThingWorx 9.2.0. This versions is no longer a supported version. Please consider an upgrade to a supported version.
    From the error message you shared it appears that ESAPI validation failed.
    Please review Article - CS270061 - Troubleshooting "Error occurred while validating HTTP header" Messages in ThingWorx Platform
    If this is a new problem what changed in your configuration?
    Have you reviewed the Database logs? Have you verified that the Database is Healthy?
    Pehowe
