upgrading twx
  • August 10, 2021
  • 3 replies
  • 2012 views
To upgrade, Thingworx 9.2/9.1/9.0 is best? and why?
Does Twx 9.2 have any legacy widgets or entities?
Best answer by PaiChung
Not sure what version you are upgrading from, there is some documentation available on upgrade as well as the release notes.
Also there is a service being offered to help with upgrading to TWX 9.x
As far as which version is best, i believe currently 9.1.1 as 9.2 got pulled and will become 9.2.1 I think.
PaiChung22-Sapphire IAnswer
22-Sapphire I
August 11, 2021
Hello @AP_9587236 ,
Which legacy widgets and entities are you looking for?
Pls specify.
Community Manager
August 17, 2021
Hi @AP_9587236.
You can find the release notes and system requirements for the 9.x releases here.  As @PaiChung stated, the version you are upgrading from will be a consideration.  There are architectural changes in the 9.x releases that will most likely require you to update any custom extensions, modify mashups, etc., so full regression testing is required following upgrade.  There are also upgrade docs available at the link provided.
You may also want to check the product calendar for support end dates for each release.
In regard to legacy widgets, they are still available in the latest releases but are expected to be removed at some point, so it would be a good idea to start switching over to the new ones at some point following your upgrade.
Please let us know if you have additional questions.
Regards.
--Sharon
Community Manager
August 25, 2021
Hi @AP_9587236.
If you feel your question was answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
