what's different between SDKgateway and Industrial Gateway (template)
Hi:
I was look into the Thingworx edge java SDK , it mention , the client can set a type of SDK gateway ; but in the Composer I will see Industrial gateway template ,which be use to connect a Kepware server .
Are they the same concept ? or the Industrial gateway was a subclass of SDK gateway ; then is it possible to implement a custom Industrial gateway directly? thanks a lot
