API to get Associated Reference Object from Windchill WRS
  • April 30, 2024
  • 2109 views
I'm Trying to get the Associtated reference objects from windchill odata services but there's no API related to that object, but in Endpoint Description they mentioned about that as shown in above image.  Any leads or solutions are appriciated.
Best answer by HelesicPetr
Hi @RC_10864577
It is time to upgrade >D
https://www.ptc.com/en/support/article/CS318837
https://www.ptc.com/en/support/article/CS254366?
PetrH
HelesicPetr
Hi @RC_10864577
What reference objects are you expecting that should be returned?
The description of reference objects point to each change type.
Here is example of Change request.
But this reference objects are linked to the change object not WTPart or EPMDocument or WTDocument
PetrH
PetrH
Hi @HelesicPetr
I'm Trying to get the reference object or an ECN.
HelesicPetr
Hi @RC_10864577
You said Reference objects but you haven't mentioned the type of source object.
I've provided example for ChangeRequest, so you can find same API for others change types.
PetrH
PetrH
