Cannot promote related or unrelated objects that exist in different folders at same time
  • April 21, 2010
  • 5 replies
  • 1265 views
PTC states that this can only be accompished if all objects reside in the same folder, Intralink 3x didn't care where the objects were located, if they were related and displayed with the parent in a Locate window all could be promoted at once, now many promotions replace one step promotion.
Kevin
If you perform an advanced search and constrain the search to a product
you can select objects from multiple folders and initiate a promotion
request from the search results.
Jeff
kjohns1011-VisitorAuthor
Jeff, this is the problem, you are confined to a Product on a Promotion,
new designs usually contain new library objects as well, and most of us
have Products and Libraries, if they are related via assemblies, then all
should be available to Promote on form just as in intralink-no?
Kevin Johnson
PDMLink- Pro/e Administrator
Instrumentation Laboratory
Bedford, Ma 01730-2443
781-861-4561 Office
781-266-7168 Cell
Kevin
Typically Library objects have a different approval process than Product
objects. For most customers I work with the only Library objects that
the general user has access to are already Released.
With that said, I do see the need to allow for the promotion of objects
across containers.
Jeff
Hi
We designed a custom add on module for search and add promotable objects to
a Promotion Request - Collect Objects step. Please refer the attached screen
shot.
If this of interest, please let us know for the pricing details.
Thank you and have a great time.
Best Regards
Swamy Senthil
973 216 0456(M)
866 908 6561(F)
Principal Solutions Architect
Swasen Inc
www.swasen.com
The WC promotion actually works better for us. For us a Promotion Request should only contain one part number and the files for that should be in the same folder.
