Different Reference Designators for Same Child Part Reused Under Different Parents
I am working on a Windchill product structure and need help with Reference Designators in a reuse scenario.
Here’s my structure:
Product Structure 1 (Top Level)
|--Parent 1
|--Sub Assembly 1
|--Child 1 with Reference Designator (e.g., R1)
|--Parent 2
|--Sub Assembly 1
|--Child 1 with different Reference Designator (e.g., R2)
Sub Assembly 1 is reused under both Parent 1 and Parent 2.
Child 1 is part of Sub Assembly 1.
Sub Assembly 1, Parent 1 and Parent 2 are Configurable Modules whereas Child 1 is a WT Part.
I want to assign different Reference Designators to Child 1 depending on which parent it is under (R1 for Parent 1 path, R2 for Parent 2 path).
However, when I try to edit the Reference Designator in the Occurrences tab, the value remains the same across both instances of Child 1.
Question:
Is it possible to assign different Reference Designators to the same child part reused under different parent paths in Windchill using OOTB solution?
