Dynamic Positioning - Options and Variants
I have a simple issue. Assume I have a geometry in my part that uses a parameter from windchill, coming from WTPart to the CAD object. The Idea is to input this attribute during the actions configure (ie. Option filter is done as well as the parameter input in the second step using parameter at top level and child resolution given to the required child). The issue is that, the child receiving this parameter, since it needs the parameter in order to propagate from WTPart to the CAD object, that respective child needs to be configurable. However, if that node is configurable, then we cannot define Locators. Is there a way to maintain the Parameter appearing because of configurable module yes and have the locators for that node appear as well.
Cheers.
