Is it possible to install Windchill on Windows 10?
NT_10748259
Version: Windchill 11.2
Use Case: For personal development I was wondering if I can install Windchill on a Windows Desktop like Windows 10 or does it strictly need to be Windows Server?
Description:
PSI loads Installation Manager but closes right after on Windows 10. Works fine on Windows Server.
I've been installing on Windows 10 for years - for dev systems and general learning.
If the machine is a company computer and is on a domain, no problem - same as a server.
If the machine is personal and not on a domain, need to edit the host file to add xxx.xxx.com so that a fully qualified hostname can be filled in.
There was a similar question before - "Installing Windchill in Windows 10 os": https://community.ptc.com/t5/Windchill/Installing-Windchill-in-Windows-10-os/td-p/674516
Hello @NT_10748259
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
