Object Initialization Rules
  • January 12, 2015
  • 6435 views
I create a document subtype named "DocsRef" What I'm trying to do is when you create a document under "DocsRef" The default folder shoul be "DOCUMENTS"
I create OIR and this is my code.
<AttributeValues objType="wt.doc.WTDocument">
<AttrValue
id="folder.id"
algorithm="com.ptc.core.foundation.folder.server.impl.FolderPathAttributeAlgorithm"
ignore="false"
force="false"
final="false">
<Arg>/wchill://Windchill/Product/Projects/Documents/</Arg>
</AttrValue>
</AttributeValues>
After that I create new rules and named it DocsRef and I choose DocsRef type and upload the xml file with the code above.
When I try to create new document under DocsRef type. I received this error.
can somebody tell me what is the cause of the error?
Thanks!
Luar
Best answer by mrane
Hi Luar,
The exception clearly states that the folder does not exist. Note the folder needs to exist before you create the document and expect to save it in the folder. Consider the OIR entry as shown below :
'Default' needs to exist and the folder ABC is the folder in which I need to store the documents. It is the first level folder.
<AttrValue id="folder.id" algorithm="com.ptc.core.foundation.folder.server.impl.FolderPathAttributeAlgorithm">
<Arg>/Default/ABC</Arg>
</AttrValue>
-Malavika
mrane1-VisitorAnswer
Hi Luar,
</AttrValue>
-Malavika
Luar1-VisitorAuthor
Hi Malavika,
Thankyou for prompt response. The error is gone but what I want to do is the path in Select Folder should be the folder path where I want my file to store. Or can I set the radio button default on Auto select Folder?
Luar
Luar1-VisitorAuthor
Hi malavika,
This is my code.
<AttrValue
id="folder.id"
ignore="false"
force="false"
final="false">
<Arg>/Default/Documents/</Arg>
</AttrValue>
<AttrConstraint id="folder.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue"/>
<Value algorithm="com.ptc.core.rule.server.impl.GetImmutableConstraint"/>
</AttrConstraint>
</AttributeValues>
Yes, the radio button on the location is gone and the location is generated. But my problem is even the other type of document it is generated on my "DOCUMENTS" folder. It supposed to be on the DocsRef type only. What am I going to do in my code?.
Thanks!
luar
