Part Instance Allocation
Version: Windchill 13.0
Use Case: The OOTB Windchill functionality appears to only allow one part instance allocation to each part included in the structure of a parent part Instance. For example, it appears that if I wished to associate 100 different instances of a child part within the structure of a parent part instance, I would first have to specify that the quantity of the child part is 100 before then allocating a unique part instance to each of the 100 rows. This could end up being quite time consuming.
Description:
I am unable to find a way of achieving the same objective in a more efficient manner. For example, it would be nice if it was possible to only include one row under the parent part instance which communicates the details of the child part. Using my example above, I could use this single row to specify a quantity of 100 before then using the "Allocate Existing Part Instance" wizard to multi-select the 100 child part instances I would like to associate with the row used to represent the child part.
Can anybody suggest a more efficient means of allocating part instances to parts listed in a part structure than the functionality detailed in the "Use Case" section of this post?
