Windchill Printing
  • January 11, 2024
  • 2 replies
  • 1005 views
I need some details on Windchill Printing.
Best answer by shussaini
Are you looking for Windchill Batch Printing?. If yes, additional information can be found here.
Hope this helps.
regards
~Syed
A better description of what you need to do would help get a better answer.
You can configure Windchill to publish drawings at check-in time, state change time, promotion request submittal, etc.
You will need the CreoView Adapter setup for the publishing. The published file can be in a number of formats, we use PDF.
With the CreoView client installed, the file can be opened from Windchill.
shussaini16-PearlAnswer
Hope this helps.
regards
~Syed
