Add binding variable to the HTML5 Video widget
Hello
I'm working to modify the HTML5 video widget
I was able to add an input event "Play" (bindable to a mashup event) that does the play of the video.
I'm now trying to add a bindable output parameter that is the length of the video (this is available with the "duration" property of the HTML5 video object)
I added this param correctly (VideoLength), I can see this on the mashup and I bound it to a label to see the value),
I can set and see a "test" value with this.setProperty('VideoLength', 100); executed when a new video file is set
but I don't know how to retrieve the "duration" DOM property ... it should be somethign like
this.setProperty('VideoLength', ???.duration???);
can someone help ?
iguerraAnswer
Great Constantine
there was more problems
  1. the video length is not available immediately after the load method call
  2. the duration value is a DOM property so cannot be read with attr("attr_name"), but with get,
    I used
    var videoPlayer = this.jqElement.find("video");
    videoPlayer.get(0).duration
So I made all by adding an event listener for the "load complete" (loadeddata) event and its service I set the VideoLength property of the widget
18-Opal
Hello @iguerra,
Try this:
document.getElementById(this.jqElementId).duration;
(be careful with this HTML5 Video extension, looks like it's removed from the Marketplace, might be deprecated or not fully compatible with the recent versions of ThingWorx)
/ Constantine
iguerra16-PearlAuthor
does not works, it returns undefined (see the last 2 lines)
	this.updateProperty = function (updatePropertyInfo) {
		var widgetElement = this.jqElement.find("source");
		// TargetProperty tells you which of your bound properties changed
		if (updatePropertyInfo.TargetProperty === 'VideoLocation') {
			var srcVideo = updatePropertyInfo.SinglePropertyValue;
			this.setProperty('VideoLocation', srcVideo);
			widgetElement.attr("src",srcVideo);
			videoPlayer.trigger('load');
			if (this.getProperty('AutoPlay')==true)
				videoPlayer.trigger('play');
			console.log("HTML5Video ID= " + this.jqElementId );
			this.setProperty('VideoLength', document.getElementById(this.jqElementId).duration);
18-Opal
I see. How about this?
this.setProperty('VideoLength', videoPlayer.attr("duration"));
/ Constantine
