Custom Object :: Launch a Bomgar Session from Axeda
* Launch a Bomgar Session from Axeda
* (1) get Bomgar ID & check logged in
* (2) generate session key and external key
* (3) create / update software package with explorer execute instruction
* (4) deploy package against supplied asset
Add the following Paramters to the Action Custom Object
user
pwd
asset
import net.sf.json.JSONObject
import groovyx.net.http.HTTPBuilder
import static groovyx.net.http.ContentType.*
import com.axeda.drm.sdk.scripto.Request
import com.axeda.services.v2.AssetReference
import com.axeda.services.v2.Model
import com.axeda.services.v2.ExecuteApplicationInstruction
import com.axeda.services.v2.SoftwarePackage
import com.axeda.services.v2.DeploymentType
import com.axeda.services.v2.SoftwarePackageCriteria
String VERSION = "2.0.0.0"
String NAME = "LaunchBomgar"
String BOMGAR_HOST = "https://your.bomgar.box.com/"
String BOMGAR_PATH = "api/command.ns"
String BOMGAR_ID = "get_api_info"
String BOMGAR_SESS = "generate_session_key"
String BOMGAR_LOGG = "get_logged_in_reps"
def toJSON(msg){
msg = [ response: msg ]
toJSON = ['Content-Type': 'application/json', 'Content':JSONObject.fromObject(msg).toString(2)]
try
String sBomgarID, sShortKey, sURL, sModel, sSerial, sExtKey, sError
Boolean bLoggedIn=false
def params = Request.parameters?.size() >2 ? Request.parameters : parameters
String sUser = params.user
String sPwd = params.pwd
String sAssID = params.asset
// find asset
Asset myAsset = bridges.assetBridge.findById(sAssID)
if (myAsset == null){
logger.info "Asset ID not found " + sAssID
return toJSON("Asset ID not found " + sAssID)
// find Model
Model myModel = bridges.modelBridge.findById(myAsset.getModel().getSystemId())
if (myModel == null){
logger.info "Model not found"
return toJSON("Model not found")
sSerial = myAsset.serialNumber
sModel = myModel.modelNumber
sExtKey = sModel + "|" + sSerial
// get my Bomgar rep id
def Query = [username:sUser, password:sPwd, action:BOMGAR_ID]
def bomgar = new HTTPBuilder(BOMGAR_HOST)
bomgar.get ( path: BOMGAR_PATH, query: Query, contentType : XML ) { resp, xml ->
sBomgarID = xml.user_id.text()
sError = xml.text()
if (sBomgarID==""){
logger.info "Bomgar (" + sUser + ") " + sError
return toJSON("Bomgar (" + sUser + ") " + sError)
// check that I'm logged in
Query = [username:sUser, password:sPwd, action:BOMGAR_LOGG]
if (xml.rep.size() > 0) {
xml.rep.each {
if ( sBomgarID == it.@id.text() ) bLoggedIn = true
if (!bLoggedIn){
logger.info "Bomgar (" + sUser + ") Not Logged In"
return toJSON("Bomgar (" + sUser + ") Not Logged In")
// create a Bomgar session key
Query = [username:sUser, password:sPwd, action:BOMGAR_SESS, type:'support', queue_id:'rep:' + sBomgarID, external_key:sExtKey]
sURL = xml.key_url
sShortKey = xml.short_key
if (sURL.size()<5){
logger.info "Bomgar Session not generated"
return toJSON("Bomgar Session not generated")
// search for existing package
SoftwarePackageCriteria softCrit = new SoftwarePackageCriteria()
softCrit.setName(NAME+sSerial)
softCrit.setVersion(VERSION)
packages = bridges.softwarePackageBridge.find(softCrit)
// delete old packages
bridges.softwarePackageBridge.delete(packages.getSoftwarePackages())
// create execute instruction which runs explorer on asset
ExecuteApplicationInstruction execIns = new ExecuteApplicationInstruction()
execIns.setPathToExecutable("explorer")
execIns.setAsyncExecution(true)
execIns.setArguments("\"" + sURL + "\"")
// create simple software package
SoftwarePackage softPack = new SoftwarePackage()
softPack.setName(NAME+sSerial)
softPack.setModel(myAsset.model)
softPack.setVersion(VERSION)
softPack.instructions.add(execIns)
result = bridges.softwarePackageBridge.create(softPack)
if ( ! result.isSuccessful() ) {
logger.info "Package error " + result.toString()
return toJSON("Package error " + result.toString())
// create software deployment
Deployment deploy = new Deployment()
deploy.setSoftwarePackage(softPack)
deploy.setType(DeploymentType.MANUAL)
AssetReference assRef = myAsset
deploy.assets.add(assRef)
result = bridges.deploymentBridge.create(deploy)
logger.info "Deployment Error" + result
return toJSON("Deployment error " + result)
else
logger.info "Session Deployed " + sShortKey
return toJSON("Session Deployed " + sShortKey)
catch (Exception e){
logger.error(e)
return toJSON(e.toString())
