How to use QueryNamedPropertyHistory service with API call
  • December 4, 2017
  • 2 replies
  • 3232 views
Hi community,
I've been trying to use the service; QueryNamedPropertyHistory() through an API call but not having any success. These are the details of my call:
Method: POST
Url: http://xx-xxx-xxx-xxx/Thingworx/Things/ThingName/Services/QueryNamedPropertyHistory?appKey==xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxx…
Body:
params = {
      "oldestFirst": false,
      "maxItems": 50,
      "endDate": null,
      "startDate": null,
      "query": null,
      "propertyNames" : {
      "rows": [{
          "name": "propertyName",
          "description": "propertyDescription"
      "dataShape": {
          "fieldDefinitions": {
              "name": {
                  "name": "name",
                  "aspects": {},
                  "description": "",
                  "baseType": "STRING",
                  "ordinal": 1
              "description": {
                  "name": "description",
                  "aspects": {},
                  "description": "",
                  "ordinal": 2
Below is my response: I would expect to see the propertyName in the response data alongside the 'timestamp' field. Does anyone have any advice?
Andy
aseaton12-AmethystAuthor
I see that the query parameter works when it is written out, for example:
...but i havent had success with a null query...any help appreciated.
Andy
You do not need to define params in the JSON body; this is working for me:
curl -X POST \
  http://localhost/Thingworx/Things/TestQueryThing/Services/QueryNamedPropertyHistory \
  -H 'accept: application/json' \
  -H 'appkey: ' \
  -H 'cache-control: no-cache' \
  -H 'content-type: application/json' \
  -H 'postman-token: 607288b1-b9c4-f9c4-bc3b-1bbe2f49cda6' \
  -d '{
   "maxItems":2,
   "propertyNames":{
      "dataShape":{
         "fieldDefinitions":{
            "name":{
               "name":"name",
               "baseType":"STRING",
               "ordinal":0
      "rows":[
            "name":"test"
Thanks James for your reply. I found success with the following example request body:
Andy
