iMonnit Cloud extension sensor services returning no results
  • March 10, 2017
  • 2 replies
  • 4450 views
Hope someone here has some experience with this extension!
All of the services return values except the ones relating to the sensors (all the useful ones).
As far as i can tell my Monnit account is set up correctly as i can get information about my gateway & network, anyone else had this issue?
The services also execute with no errors, just return empty infotables.
20-Turquoise
March 10, 2017
Antony Cyriac​ could you please provide any feedback/information on this?
Stephen Fresta , can you comment on this?
7-Bedrock
March 10, 2017
Hi Matthew,
Can you try executing the service "SensorNameGet" with just the SensorID of one of your sensors?
It should return an infotable "result" with the value of the name of the sensor.
The extension seems to be working for me so far, I have just tested (what version of Thingworx are you on?)
mfelton1-VisitorAuthor
Thanks for the fast replies guys,
I can get the name returned through that function, the services that return empty tables for me are:
SensorChartMessages
SensorDataMessages
SensorGet
SensorGetCalibration
SensorGetExtended
SensorList
SensorListExtended
SensorNotificationList
All i want to do is get a list of the sensors, and then when one is selected, display its current value and then a graph of its last 20 or so values. So far i can get the network information & the gateway, while good its not exactly the point of what i want to do!
I'm using Thingworx 7.1 PorstgreSQL version.
7-Bedrock
March 17, 2017
Hi Matthew,
Thanks for that information. You're right, it seems like there was a recent update to the API that is rendering some services unable to obtain data back from iMonnit servers.  I am seeing the same thing.  The services return null, which is what you're getting, when the API call gets unusable information back from iMonnit.
The extension will require an update.
We will put this on our plates right now -- but I cannot give you a timetable at the moment. Thank you for bringing it to our attention and sorry that it isn't working for you. I will keep this thread updated when we find out more.
