Infotable column reference as inputParameter
Hi Guys,
i need you help once more.
I have a service which takes one input parameter:
propertyName (string)
I query a DataTable and goes through the results like this
var myTable = infotable result from queryDataTableEntries
var tableLength = myTable.rows.length;
for (var x = 0; x < tableLength; x++) {
y = myTable.rows.propertyName;
however this reference does not seem to work. If I dont use reference and place some existing column name then it works.
Is there any special syntax for indirect reference (like for things, Thing[yourThing].property ....)?
