Infotable filter AND/OR
I am using the infotable filter functions, when I use single filter it works but when I try to nest AND/OR it doesn't work. I have Activity area, start time, end time and shift name as inputs. I wanted to nest like
(Activity area or (Start time and End time and Shift Name))
I have gone through the examples given in help by ptc but when I try it, it doesnt execute the way I want. It throws error like must bind data shape but I have already binded a datashape.
Please help me with where I am going wrong.
//call close session
//me.getcloseSession();
var headers = { "Content-Type": "application/json"};
var url = "http://"+ me.host + ":" + me.port + "/api/shifts/"+parameterID;
var params = {
proxyScheme: undefined /* STRING */,
headers: headers /* JSON */,
ignoreSSLErrors: undefined /* BOOLEAN */,
useNTLM: undefined /* BOOLEAN */,
workstation: undefined /* STRING */,
useProxy: undefined /* BOOLEAN */,
withCookies: undefined /* BOOLEAN */,
proxyHost: undefined /* STRING */,
url: url /* STRING */,
timeout: 15 /* NUMBER */,
proxyPort: undefined /* INTEGER */,
password: undefined /* STRING */,
domain: undefined /* STRING */,
username: undefined /* STRING */
// result: JSON
try {
var json = Resources["ContentLoaderFunctions"].GetJSON(params);
var param1s = {
infoTableName : "InfoTable",
dataShapeName : "Ferrara_Shiftnfo_DS"
var newInfo = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(param1s);
var tStartTime;
var tEndTime;
for(var i=0; i<json.Items.length; i++)
if (json.Items[i].Shift.StartTime.length > 20)
tStartTime = parseDate(json.Items[i].Shift.StartTime.replace("T", " "), "yyyy-MM-dd HH:mm:ss.SSS");
else
tStartTime = parseDate(json.Items[i].Shift.StartTime.replace("T", " "), "yyyy-MM-dd HH:mm:ss");
if (json.Items[i].EndTime.length > 20)
tEndTime = parseDate(json.Items[i].EndTime.replace("T", " "), "yyyy-MM-dd HH:mm:ss.SSS");
else
tEndTime = parseDate(json.Items[i].EndTime.replace("T", " "), "yyyy-MM-dd HH:mm:ss");
if (json.Items[i].Shift.Name != null &&
json.Items[i].Shift.Name != '' && json.Items[i].Shift.Name != ' ' && json.Items[i].Shift.Name.length != 1)
// if (json.Items[i].ActivityAreaName == activityName)
newInfo.AddRow({parameterSet:json.Items[i].Id,
activityArea:json.Items[i].ActivityAreaName,
WorkCellConfigId: json.Items[i].WorkCellConfigId,
ActivityAreaId: json.Items[i].ActivityAreaId,
shiftName:json.Items[i].Shift.Name,
startTime:tStartTime,
endTime:tEndTime,
State: json.Items[i].State,
Number: json.Items[i].Shift.Number
result1 = newInfo;
var query = {
"filters": {
"type": "OR",
"filters": [
"type": "AND",
"filters": [
"type": "EQ",
"fieldName": "startTime",
"value": startTime
"type": "EQ",
"fieldName": "endTime",
"value": endTime
"type": "EQ",
"fieldName": "shiftName",
"value": shiftName
"type": "EQ",
"fieldName": "activityArea",
"value": activityName
var params2 = {
t: result1/* INFOTABLE */,
query: query /* QUERY */
var result2 = Resources["InfoTableFunctions"].Query(params2);
var params4 = {
t: result2/* INFOTABLE */,
query: sort /* QUERY */
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].Query(params4);
catch(err)
me.getCloseSession();
Thanks in advance.
@svisveswaraiya_285988
It might be useful to break down your code and work only with the query to make sure there is a problem with it.
I have done a simple test with just that query and it looks like it works for me.
I have attached the sample entity I used, I just entered a few random values in the QueryIT infotable in properties page and ran the query with some various values, and the output was as expected.
Might be interesting for you to check with that entity to confirm if you see something odd or if it works ok... then maybe the problem is something else or may need to try with data closer to what you actually have - might be an issue depending on the type of data.
Hope this helps
Christophe
Hi @cmorfin,
Thanks for your swift response.
The entities you sent throws error and did not get imported for me.
