Migration Issue
  • August 12, 2016
  • 2 replies
  • 3819 views
While migrating things from version 6.5 to 7.1.2 version.
We are getting below error:
Error importing: error, Import Failed: [1,018] Data store unknown error: [Error occurred while accessing the property provider.] .
We have already imported all the necessary datashape and Thingtemplate.
Can you try importing while checking the box labeled "Use Default Persistence Provider"? Let me know if that changes anything.
August 13, 2016
Hi Tori,
We have tried to import by checking the box "use default provider" also, but it's nit working.
The same thing is working in 6.5  version.
Aditya Kumar
Aditya, this is the Postgres version, correct? Are you trying this as an admin-level user?
20-Turquoise
August 15, 2016
Do you have all of the necessary extensions installed? Are the entitiesd you are  trying to import a part of an extension?
If you are using the postgresql, have you updated the DB schemes consecutively (i.e, running the script from 6.5 to 6.6, then 6.6 to 7.0, 7.0 to 7.1)?
@Aditya​, I would agree with Polina and would like to add few comments. The issue is quite frequent for 6.5 to 7.0 migration, inorder to overcome the dependency issues, I would suggest to go for an incremental migration i.e., 6.5 to 6.6, 6.6 to 7.0 etc.,
Also, let us know if you were using 6.5 Postgres.
-Giri
We are using version Thingworx 6.5.0-b460, and I think we are not using Postgresql. and
