Raspberry PI OS (Buster) EMS - SSL handshake error / Verify Failed / twWs_Connect: Error restarting
- 13 replies
- 9731 views
- Translate All
I am currently running EMS version MED-61060-CD-054_SP9_Microserver-Linux-arm-hwfpu-openssl-5-4-9-1154 on Raspberry PI OS (Linux ems01 4.19.118+ #1311 Mon Apr 27 14:16:15 BST 2020 armv6l GNU/Linux) and am trying to connect to the 30 day hosted trial of TW.
I am using this guide "Setup a Raspberry Pi as an IoT Device". This guide specifies to use Buster and version SP5 of the ems, which I have also tried. I have worked through several of these guides and many of the solutions offered on this forum but still cannot get the Linux RPI version to work. I have been able to get the Windows version of the EMS to connect to my online instance of TW.
As it stands, I am now getting the following error:
TW_NEW_SSL_CLIENT: SSL handshake error. Error: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed.
SDK: twWs_Connect: Error restarting socket. Error 0
If I follow the suggestion to set encryption to:
"ws_connection": {
"encryption": "none"
I get:
[TRACE] 2020-06-15 19:01:53,984 SDK: twWs_Connect: Got Response from Server:
HTTP/1.1 400
Content-Type: text/plain;charset=ISO-8859-1
Connection: close
Bad Request
This combination of host and port requires TLS.[ERROR] 2020-06-15 19:01:53,991 SDK: twWs_Connect: Error initializing web socket. Response code: 400
I have tried various combinations of raspbaerry pi OS version from "jessie, "sketch" and "buster" using each of the suggested EMS versions and continue to end up with various errors. This is the closest I have come to getting it to work. From the logs it appears to be connecting to the remote server.
Below is my config.json
"ws_servers": [{
"host": "pp-##########.devportal.ptc.io",
"port": 443
"resource": "/Thingworx/WS",
"appkey": "##################",
"logger": {
"level": "TRACE",
"publish_directory": "/home/pi/microserver/logs",
"publish_level": "TRACE",
"max_file_storage": 2000000,
"auto_flush": true
"http_server": {
"ssl": false,
"authenticate": false
"ws_connection": {
"encryption": "ssl"
"certificates": {
"validate": false
"tunnel": {
"buffer_size": 8192,
"read_timeout": 10,
"idle_timeout": 300000,
"max_concurrent": 4
"file": {
"max_file_size": 8000000000,
"virtual_dirs": [{
"other": "/home/pi/microserver/other"
"tw": "/home/pi/microserver/tw"
"updates": "/home/pi/microserver/updates"
"staging_dir": "/home/pi/microserver/staging"
"data_security": {
"key_hash": "#############"
I enabled TRACE to hope to find some additional info in the logs. I am attaching it as a file.
I appreciate any help you can offer.
Dave
