Sorting grid column
  • June 11, 2015
  • 5 replies
  • 7878 views
I have one grid which is updating dynamically.
I want particular column to be sorted automatically, like latest records should be on always top.
Please provide any solution for this.
Thanks.
    Hi Praveen,
    I recommend you use the Sort function in your service to deliver the data sorted to the client side.
    (Query also supports Filter and Sort so you can do that too)
    Am i being silly or not ?
    I'm doing this :
                var sort = new Object();
                sort.name = "myColumnName";
                sort.ascending = true;
                Infos.Sort(sort);
    But I keep getting that error :
    But the Infos dataTable isn't null.
    [TransformResultSetStations] :JavaException: java.lang.IllegalArgumentException: Invalid format: "org.mozilla.javascript.Undefined..."
    22-Sapphire I
    April 6, 2017
    Try this snippet
    var params = {
      sortColumn: undefined /* STRING */,
      t: undefined /* INFOTABLE */,
      ascending: undefined /* BOOLEAN */
    // result: INFOTABLE
    var result = Resources["InfoTableFunctions"].Sort(params);
    praveenp1-VisitorAuthor
    I used Sort function, but i am getting following error
     "Wrapped java.lang.Exception: Unable To Convert From java.lang.String to INFOTABLE Cause: Unable To Convert From java.lang.String to INFOTABLE"
    var params = {
        sortColumn: "timestamp" /* STRING /,<br>    t: "ClientName_Events" / INFOTABLE /,<br>    ascending: true / BOOLEAN */
    Here in code :
    "timestamp" is my column name,
    "ClientName_Events" is INFOTABLE,
    Tried BaseType as Text, DateTime and InfoTable.
    Is am doing anything wrong?
    Hi Praveen,
    In your code you try to pass a String as an Infotable, meaning here: t: "ClientName_Events" /* INFOTABLE */, I presume that you wanted to say actually:
    t: ClientName_Events /* INFOTABLE */, ?
    BR, Vladimir
    Hi, is it possible to sort on many columns, one after another using Sort, like "ORDER BY" of SQL ?
    22-Sapphire I
    July 28, 2016
    Yes, you can use the Query statement to do a multi query/sort
    See this: Query Parameter for Query Services
    Hello
    I would like to do this sorting on a particular column for a Grid generated automatically with "GetImplementingThingsWithData" .
    How could I access to the associated query to add the "sort" parameter ?
    Or should I generate the grid by another way ?
    Pascal
    Hello, if you can use the service QueryImplementhingsWithData instead, the input parameter "query" can be provided with sort statement
    Thanks for advice
    The problem is that I have a large number of widgets already associated to the service datas so it will be a large rework (I don't know if there is an easy way to replace the service in the mashup or somewhere without loosing all dependencies ? )
    I just read that in 7.4 grid will be improved perhaps it will cover my needs with less efforts  ?
    These features will be available at the end of March 2017.
    • Advanced Grid: New grid widget with improved design, context menu, multi-column sorting, global search and many more common grid-related features.
    But I'll use this service for further mashups
