Unable to delete Application Key TwxRuntimeKey_Administrator
  • August 11, 2017
  • 3 replies
  • 2513 views
Dear Team,
Why am I getting this  error -- Unable to delete Application Key TwxRuntimeKey_Administrator
    Hello, Bhuwaneshwar Gupta.
    Please take a look at the post
    What is the TwxRuntimeKey_Administrator? And what is its use?
    I'll echo the question asked there:
    Is this in a default instance, with Navigate, Utilities?
    -- Craig A.
    bgupta-210-MarbleAuthor
    Thanks Craig,
    Given link is unable to open showing unauthorized access.
    What is default instances, with Navigate, Utilities?
    22-Sapphire I
    August 14, 2017
    If you are not using Navigate at all, are you at all using the Push Updated Properties to Clients Feature?
    i.e. In your mashup you are using GetProperties and have enabled the 'send data when a property is updated'
    When this feature is enabled and a user is logged and viewing a mashup it will create an account specific appkey temporarily.
    Thanks Pai Chung,
    Is this error create any problems in our applications?
    Thanks Pia Chung
