While loading the Thingworx composer I am getting error "Failed to return license click check" and loading is failed
  • March 21, 2017
  • 2 replies
  • 5546 views
when i am loading thingworx composer i get an alert message saying failed to return license click check and thingworx is not loading
Hi Priyanshi Saxena​, please check this article: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS189387and let us know if it answers your problem.
psaxena1-VisitorAuthor
I have already read this document but it only states the possible causes without any substantial solution to it and furthermore the log files of error doesnt give any meaningful error message.
the only understandable error message which i found in tomcat log was :
The web application [/Thingworx] registered the JDBC driver [org.postgresql.Driver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
Can we comprehend anything from this?
My Thingworx composer is loading properly on my server in which thingworx is installed but when i access it from another system using the ip of the server it gives me the error failed to return license.
I have already added the inbound and outbound rules in the firewall for 8080 port to allow access from any ip.
