Why doesn't FindDataTableEntries work with multiple values is given Values infotable
  • April 14, 2016
  • 3547 views
When I happen to use FindDataTableEntries on DataTable, by setting multiple rows in Values Infotable, I get an error as below
Unable to Invoke Service FindDataTableEntries on WA_SampleGuidNameProductionValueTable : Invalid Number of values provided to FindDataTableEntries in WA_SampleGuidNameProductionValueTable
But FindDataTableEntries work for single row in Values infotable.
    Anirudha, I believe FindDataTableEntries input parameter is not intended to work with a multiple row infotable. It only accepts a single row infotable, tries to match the specified values and then print them.
    ahanchat5-Regular MemberAuthor
    Ok, Then which service to use if I have multiple values.
    I tried using QueryDataTableEntries as below, but I don't get any values. What is the right way to use QueryDataTableEntries?
    I appreciate your reply, I am stuck into an critical issue and it is affecting our production server. Please help.
    var str1 = "19be81d24259853a99fc15fdcda63934521bae29";
    var str2 = "2052527c1afe8af884d387d544ab2d2b3c0e1ab9";
    var jsonArray = [str1, str2];
    var query = {
        filters: {
            type : "EQ",
            fieldName : "guid",
            values: jsonArray
    var values = me.CreateValues();
    var params = {
        maxItems: undefined /* NUMBER */,
        values: values /* INFOTABLE*/,
        query: query /* QUERY */,
        source: undefined /* STRING */,
        tags: undefined /* TAGS */
    // result: INFOTABLE dataShape: "undefined"
    var result = me.QueryDataTableEntries(params);
    Please note that there is typo, The type I have used is "IN"
