Allow direct modification of step number in Editor
  • July 16, 2024
  • 0 replies
  • 524 views
It should be possible to edit the number of a step directly. This would allow you to quickly move the eleventh step of a procedure to position 3, for example. In any case, this would be much faster than using drag and drop to move the step up in the sequence step by step.
