Jun 20, 2022 1:25 PM UTC
How to call tml3dRenderer from external .js file
Hello everyone, I've downloaded a sample Hololens project with PDF reader included (via external library pdf.js) and it works fine both in Hololens and preview.
Other than the external library there's also some code in Home.js that initialize and handles the reader variable, I want to move this code to an external file too for legibility purpose.
The problem occurs when code try to execute a line where 'tml3dRenderer' is in use:
"PDFreader.js:181 Uncaught (in promise) ReferenceError: tml3dRenderer is not defined "
there's a particular way to refer interal components (like tml3dRenderer is) from external files that I'm missing?
Once external .js is appendend to HTML document.head shouldn't it be recalled like the code is wrote directly in Home.js?
I'm relatively new to angular/web js development and after some google searches I can't find anything useful,
p.s. can't retrieve where I've downloaded the project so I've attached here a copy
Jun 21, 2022 7:15 AM UTC
I tested this with the simple approach mentioned in the previous post and it seems to work. OK possibly it is  not the best solution but it work. In the code I tried  simple to ensure that PDF js is loaded  and therefore I used timeout of 1 sec. OK possibly it will work with smaller time interval or in some then block. Attached it to the project
Jun 20, 2022 3:20 PM UTC
Hi @Roccobarocco ,
so possibly you can define a local variable in your code what you can later set via setter function something like this
//in your code
var my3dRenderer= undefined
function setMyVariable(tmlRender)
{my3dRenderer= tmlRender;}
// then in the module call e.g.
my3dRenderer.setTranslation('model-1-/0/1, 1.0, 0.0, 0.5 );
//etc
then load the code:
//---------------Loading the API-----------------------
$scope.asyncLoadScript = function (fname) {
 return new Promise((resolve, reject) => {
 if(fname) { var head = document.head || document.getElementsByTagName('head')[0],
 script = document.createElement('script');
 script.async = true; script.onload = resolve;
 script.onerror = reject; script.type = 'text/javascript';
 script.src=fname; head.appendChild(script); } });}
//$scope.asyncLoadScript("app/resources/Uploaded/test.js")
var mathe =undefined;
$scope.pdfModuleLoad = function() {
console.log("pdfModuleLoad started");
var pdf =undefined;
$scope.asyncLoadScript("app/resources/Uploaded/MyPdfFunc.js").then(
 function() { console.log("myMathFunc was loaded successfully") ;TESTLOAD();
//and later try to pass the tml3DRenderer to the module
$timeout( ()=> {setMyVariable(tml3dRenderer)},300)
 function() { console.log("error for when loading myPdfFunc.js module");} );
$scope.pdfModuleLoad(); //LOAD dhere the myMathFunc.js for
 So far I know such construct will not work if you will try to call this js in  a second thread /according in https://www.w3schools.com/html/html5_webworkers.asp and https://medium.com/jspoint/achieving-parallelism-in-javascript-using-web-workers-8f921f2d26db
Jun 20, 2022 3:40 PM UTC
I downloaded your project but after fast check in preview - there were no any errors and pdf was displayed fine. What should we change to reproduce the issue. Thanks
Jun 20, 2022 4:56 PM UTC
Hi @RolandRaytchev  and thanks for your fast reply.
I plan to use this PDF reader in more complex experiences than this one, so my objective is to move code from Home.js in external ,js and call from there.
I've already tried to copy&paste the code in external .js file (PDFreader.js) and import it at the beginnig of the experience with:
$scope.asyncLoadScript('app/resources/Uploaded/PDFreader.js')
 everything seems ok, the import log 'success' but when i call the loadPDF function that use the tml3dRender line of code, that's when the error comes out.
