Mar 5, 2020 11:29 AM UTC
How to scale in and scale out 3D images on triggering visible function
 Is it done by Javascript or can CSS animations be applied to 3D images
Mar 10, 2020 11:25 AM UTC
Hi @Ace_Rothstein_310668 ,
I review the video link what you mentioned in your post. Unfortunately I do not know exactly how it was exactly implemented  here  , but I think this effect could be done by moving the 3dImage widget e.g. in Z direction and scaling the 3dImage at the same. time.
I did test it in a simple project, and I think it works.
So have only 2 widgets 3DImage-1 Widget and toggle-1 Widget. So, I used the click event of the toggle to FlyIn and FlyOut effect. It is not perfect but works.
I used the following code:
var zMax=2
var zMin=0
var dist = zMax - zMin
var moveTime=2000 //ms
var moveTimeStep=10 //ms
var distInt= dist/(moveTime/moveTimeStep)
var scaleFactor =0.92
var scaleMax=0.3
var scaleMin = scaleMax *( Math.pow(scaleFactor,(moveTime/moveTimeStep)))
$scope.app.FlyIn = function(){
console.log("called app.FlayIn()")
$scope.setWidgetProp('3DImage-1', 'z',-zMax)
$scope.setWidgetProp('3DImage-1', 'scale',scaleMin)
$scope.setWidgetProp('3DImage-1', 'visible',true)
$scope.setWidgetProp('toggle-1', 'disabled',true)
var tt = setInterval(function(){ $scope.startFlayIn() }, moveTimeStep);
setTimeout(function() { clearInterval(tt);
 $scope.setWidgetProp('3DImage-1', 'scale',scaleMax)
 $scope.setWidgetProp('toggle-1', 'disabled',false)
 }, moveTime);
$scope.app.FlyOut = function(){
console.log("called app.FlayOut()")
$scope.setWidgetProp('3DImage-1', 'z', zMin)
$scope.setWidgetProp('3DImage-1', 'scale', scaleMax)
var tt = setInterval(function(){ $scope.startFlayOut() },moveTimeStep);
 $scope.setWidgetProp('3DImage-1', 'visible',false)
 }, moveTime);
$scope.app.ClickAction = function(){
if($scope.view.wdg['toggle-1']['value']==false) $scope.app.FlyIn();
 else
 $scope.app.FlyOut();
 $scope.startFlayOut = function(){
 var newVal= parseFloat($scope.view.wdg['3DImage-1']['z']) -distInt
 $scope.setWidgetProp('3DImage-1', 'z', parseFloat(newVal))
 var newScale= parseFloat($scope.view.wdg['3DImage-1']['scale'])*scaleFactor
 $scope.setWidgetProp('3DImage-1', 'scale', parseFloat(newScale))
 $scope.$applyAsync()
 $scope.startFlayIn = function(){
 var newVal= parseFloat($scope.view.wdg['3DImage-1']['z']) +distInt
 var newScale= parseFloat($scope.view.wdg['3DImage-1']['scale'])/scaleFactor
I attached also the test project
Mar 5, 2020 3:37 PM UTC
Can you describe your use case in detail?
Mar 6, 2020 4:49 AM UTC
In the example mentioned here: (https://www.youtube.com/watch?v=ERa8sN837h0. ) Half way in the middle of the experience, there is an effect added to the 3D images which makes it appear to scale up after triggering some button.
var zMax=2
var zMin=0
var scaleMax=0.3
 }, moveTime);
 }, moveTime);
 else
