10.0 Upgrade Error
  • July 14, 2011
  • 5 replies
  • 965 views
When I am at the Update Container Templates section, I get an error when it tries to Authenticate session user after starting the server/method managers.
The error is setAdministrator failed.
Brian,
I'm getting the same error trying to upgrade from 9.1 M030 to M060. Any
ideas? I've placed a call with PTC.
Mike
You can try to authenticate with the userid/password you are using from command line to check if that is the correct one. From windchill shell execute wt.auth.Authentication enter the userid/password when prompted. It should tell you whether or not you are successfully authenticated. Also when I ran into this error, I had to switch off our 3rd party authentication( siteminder) to get around the issue.
Hope this helps.
Alexius C. Chukwuka
IT Analyst, Global SAP Basis - TCM
Deere & Company World Headquarters
400 19th St, Moline, IL 61265
Thanks goes to Bryan who had the same issue.
Okay, it turned out to be a port issue with Apache.
In the file <windchill>\apache\conf\extra\app-windchill-auth.conf, the following was set:
<authnprovideralias ldap=" windchill-administrativeldap=">
AuthLDAPURL "ldap://localhost:80/ou=people,cn=AdministrativeLdap
I changed it to:
AuthLDAPURL "ldap://localhost:389/ou=people,cn=AdministrativeLdap
At least I've gotten past that point now.
Brian Toussaint
CAD Administrator
Hoshizaki America, Inc.
"A Superior Degree Of Reliability"
618 Hwy. 74 S., Peachtree City, GA 30269
What set LDAP port to 80 here? Did someone enter the wrong port during
installation?
I had similar thoughts as well. That port # is usually defaulted to 389, unless someone changed it inadvertently or fat fingered it.
Alexius C. Chukwuka
