Flexible parameters
If I have a compononent with a flexible parameter which value is set in an assembly. Does anyone know if it is possible to see the value of a flexible parameter in Windchill?
For example go to the structure tab of an assembly in Windchill. Here I can add different parameter to the view. I would love to be able to see the value of the flexible parameter in a certain assembly.
