Free - XSV (CSV, TSV) to XML Converter
*If you are doing migration projects or load data to Windchill/ PDMLink,
this is a must have FREE solution. If you find bugs or want to contribute
let me or the admin of * *
know.*
XSV to XML Converter (Free)
The XSV to XML converts CSV, TSV or any delimited files to XML files with
very little effort. Mainly, it gives you a lot of control over processing of
data during conversion.
During migration or loading exercises, many times, you need to convert
delimited data (CSV, TSV etc) to XML load files. Sure, you can use out of
the box converter to achieve this, but often, you want more control.
*Imagine loading 10,000 objects and the loader throws error while loading
999th object stating "Folder not Found" or "Incorrect Format"*
With this converter, you will be able to achieve the following.
1. Validate rows that qualify for loading. For example, validate data
against existence of folder in the system. You can validate columns using
existing validation methods or write your own in a very easy manner.
2. Format columns. For example, formatting date field. You can format
columns using existing formatting methods or write your own in a very easy
manner.
3. Dynamically calculate value for columns. For example, display data to
internal value mapping.
4. Move invalid rows into separate file and convert valid rows to
loadable XML
5. Log4J integration and logging that clearly shows columns that are
invalid and the reasons for them to be invalid.
6. Easily customize existing conversion framework to suite your needs.
Read more and get the solution free from
know.*
manner.
loadable XML
