Oct 21, 2025 2:43 PM UTC
Maturity phase change without Revision.
Wondering who has implemented this?
I did at one med device to allow pre-production CAD items to be promoted to Production when no data had changed if they provided appropriate supporting (validation) documents in the change.
Why:
Forcing a revision creates work that is not needed for the data authors and approvers.
We use the same rev scheme and we can watermark / stamp (cover page) to show the effectivity and state.
Catalina
Community Manager
Oct 28, 2025 3:26 PM UTC
Hi @lgrant
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
joe_morton
Nov 25, 2025 7:20 PM UTC
Yes, this is how we operate. For us, new objects start at revision A.1 with state Work In Progress. They iterate until ready, say A.15, then the user promotes to a released state for prototyping. A.15 is now in the state for Prototype. If there are no further changes to the design (just additional documents), revision A can go to Production.
If a design change is needed at any point, the user starts a new revision and the design goes to B.1 with state Work In Progress again.
Dec 1, 2025 1:04 PM UTC
Hi @joe_morton
Good to know. We are considering using a different Version series for just the State change.
Something like this:
In concept/development it would be 1.Iteration, 2.iteration (1.1 IN WORK, ... 1.5 Concept, 2. 1 IN WORK... 2.4 Development)
then the Version that would be promoted would have a number added to that Revision if it was not revised.
1.5 Concept would become 1.1.5 Development.
The second digit would only be used on that state change.
1.5 Concept -> 1.1.5 Development, A.1.1 Production
If 1.1.5 Development was revised it would be 2.1
When A.1.1 Production is revised it would be B.1
In this way, there is what looks like an iteration in the History table with the new change listed above the previous change and a new date etc.
Since the Revision does not change, the associated objects that may reference that version would not need to be revised.
The only issue would be objects that change from numeric to alpha if the associated object had a table that named the Rev. Not all our objects start at numeric and move to alpha.
joe_morton
Dec 1, 2025 5:01 PM UTC
Hi @Ladric
Thanks for the follow up. To be honest, I didn't really follow that completely. From the bit I did follow, I see a red flag I'd recommend you review before proceeding.
The normal Windchill versioning, as you know, is Revision.Iteration but there is at least 1 case where a 3rd indicator is used. You should be extremely careful adding a 3rd indicator and make sure it will be compatible with these cases (and possible more I'm not aware of):
  • Projects - These use a 3rd indicator. If you checkout A.1 from a Product/Library, it can be iterated within the Project as A.1.1, A.1.2, etc. When it is checked back in, it will become A.2 in the Product/Library.
  • Manufacturing BOMs - I'm not as knowledgeable here, but there are cases where a 3rd indicator is used
In both of those cases, the 3rd indicator is a lower type of change than the iteration. I think your concept is problematic because in the example you gave, "1.5 Concept -> 1.1.5 Development" the new 1.1.5 would look like the 5th update to 1.1.
