Measurement System Question
  • July 24, 2013
  • 0 replies
  • 469 views
10.1 M040
What is the default unit system that Windchill uses when I input a value into a Part attribute that is a Real With Units? Is it the unit system defined by the wt.properties property wt.units.defaultMeasurementSystem?
If so, is this measurement system also the one that the business rules would use when checking the attribute value? For example to check that mass<=500. What measurement system is used here?
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CE885A.8DCF2480]
