PDMLink Solutions: Does anyone have experience with, or a script to move large numbers of EPMDocumen
  • April 29, 2010
  • 567 views
PDMLink Solutions:
EPMDocument and SubFolder objects?
We have a PDMLink 9.1 M040 system that manages Pro/E CAD data (EPMDocument
objects).
In November, we plan to move our Windchill 8 data into that PDMLink
system.
Our plan is to use the existing CAD libraries for our parts, documents,
and changes in Windchill 8 using extract and load tools that we are
building.
However, we want to move all of our CAD folders and objects from their
current Context into a "/CAD" subfolder in the same context. Basically,
all the existing data in each library needs to go "down" one level.
Using the out of the box multi-select, copy/paste, we can do this
operation, but it takes hours to move the volumes of data we have in just
one subfolder in one library. Therefore, we need a programmatic way to
move these folders and EPMDocuments.
Has anyone done this kind of mass-move before? Do you have any scripts or
programs that were useful that you could share?
Thank you.
Albert Anderson
Solar Turbines Incorporated
San Diego, CA
Albert,
You do not need to move all the data, only the highest level sub-folders they are in, provided you don't have everything locateddirectly at the root. I guess moving a folder does not physically move the datait contains, only the references.
Or am I missing something ?
Vincent
In Reply to Albert Anderson:
PDMLink Solutions:
objects).
system.
building.
Thank you.
Albert Anderson
San Diego, CA
