Oct 8, 2025 12:05 PM UTC
Vault reuse
We have our vaults set to 25K while the default is 50K and Microsoft says the 50K per folder is an okay limit.
If we go back and change the limit to 50K and make the existing vaults writeable again, will Windchill start putting the files in vault 1 or continue with the last folder used and then move to the next new folder?
jlecozAnswer
Oct 9, 2025 7:43 AM UTC
Did the test long time ago. It will not write in the old folder. The setting will apply on the currenly used folder, and future folders.
If you want to "fill" all your folders you should do a revault and remove your vaults but this is another story....
avillanueva
23-Emerald II
Oct 8, 2025 12:33 PM UTC
I think if the folders are auto-managed the order is greyed out so it will likely just write to the same one. If you want to reset things, you can create a new vault, change mapping rules to point to it and then let the system revault and it should move all the content the new vault, creating new folders under the 50k limit rule. Eventually, all the old folders and vault will have unreferenced files and can be unmounted.
I had manually managed vaults a while back and used this process to shift over to a vault with automatic folder creation.
Oct 8, 2025 4:15 PM UTC
At the end of the day it doesn't matter because the total number of files on disk won't be impacted.  But my obsessive compulsive kicks in and I go back and set the folders to read/write again at the DB level.  As they fill up, they will be set back to read-only again.  It follows the vault folders sequence order.
update FvFolder set readOnly=0;
Doing a new vault frequently leads to cleanup frustration at the end of the revaulting process.  There are a few files that just won't move or prove challenging to clean up.  It is simpler to toggle the read-only switch and let the existing folders auto-fill again.
FYI: Not all hardware is equal.  Use caution upping the limit on poorly performing hardware.  50k is fine in most environments today.
20-Turquoise
Oct 8, 2025 4:47 PM UTC
We use 100k here with RHEL and zfs.
avillanueva
23-Emerald II
Oct 8, 2025 5:04 PM UTC
I feel like I should get a prize. 1M here.
jlecoz15-MoonstoneAnswer
