Windchill REST API custom function return collection of custom type
  • April 19, 2021
  • 3468 views
How to modify the bellow example such that the custom function returns a collection of custom complexType records as JSON instead of only a single record?
rest/custom/domain/ToastsDomain.json
	"name": "ToastsDomain",
	"id": "ToastsDomain",
	"description": "ToastsDomain Domain",
	"nameSpace": "CUSTOM.ToastsDomain",
	"containerName": "Windchill",
	"defaultVersion": "1"
rest/custom/domain/ToastsDomain/v1/complexType/Toast.json
 "name": "Toast",
 "collectionName": "Toasts",
 "description": "No description.",
 "attributes": [
 "name": "key",
 "type": "String"
 "name": "value",
 "type": "String"
rest/custom/domain/ToastsDomain/v1/import.json
	"imports": [
		{"name": "PTC", "version": "3"}
 "includeImportedEntitySets":false,
 "usePropertyPaths":true,
 "functions": [
 "name": "GetToasts",
 "importName": "GetToasts",
 "includeInServiceDocument": false,
 "parameters": [
 "name": "input",
 "type": "String",
 "isNullable": false
 "returnType": {
 "type": "CUSTOM.ToastsDomain.Toast",
 "isCollection": false
function function_GetToasts(data, params) {
	var input = params.get('input').getValue();
	var ComplexValue = Java.type('org.apache.olingo.commons.api.data.ComplexValue');
	var complexValue = new ComplexValue();
	var Property = Java.type('org.apache.olingo.commons.api.data.Property');
	var ValueType = Java.type('org.apache.olingo.commons.api.data.ValueType');
	complexValue.getValue().add(new Property("String", "key", ValueType.PRIMITIVE, 'msg'));
	complexValue.getValue().add(new Property("String", "value", ValueType.PRIMITIVE, input));
	var EntityAttribute = Java.type('com.ptc.odata.core.entity.property.EntityAttribute');
	var PropertyValueType = Java.type('com.ptc.odata.core.entity.property.PropertyValueType');
	var entity = new EntityAttribute(null, 'Toast', PropertyValueType.COMPLEX, complexValue);
	return entity;
current output of GET http://<windchill_url>/Windchill/servlet/odata/v1/ToastsDomain/GetToasts(input='hello')
 "@odata.context": "http://<windchill_url>/Windchill/servlet/odata/v1/ToastsDomain/$metadata#CUSTOM.ToastsDomain.Toast",
 "@PTC.AppliedContainerContext.LocalTimeZone": "Europe/London",
 "key": "msg",
 "value": "hello"
 desired output example
 "records": [
 "key": "msg",
 "value": "hello"
 "key": "msg2",
 "value": "world"
Best answer by James62
Bellow is the solution that outputs just a couple of records.
 "name": "Toast",
 "attributes": [
 "name": "key",
 "type": "String"
 "name": "value",
 "type": "String"
	"imports": [
 "functions": [
 "parameters": [
 "name": "input",
 "type": "String",
 "isNullable": false
 "name": "input2",
 "type": "String",
 "isNullable": false
 "returnType": {
 "isCollection": true
	var input2 = params.get('input2').getValue();
	var List = Java.type('java.util.ArrayList');
	var list = new List();
	complexValue.getValue().add(new Property("Edm.String", "key", ValueType.PRIMITIVE, 'msg'));
	complexValue.getValue().add(new Property("Edm.String", "value", ValueType.PRIMITIVE, input));
	list.add(complexValue);
	complexValue2 = new ComplexValue();
	complexValue2.getValue().add(new Property("Edm.String", "key", ValueType.PRIMITIVE, 'msg2'));
	complexValue2.getValue().add(new Property("Edm.String", "value", ValueType.PRIMITIVE, input2));
	list.add(complexValue2);
	var entities = new EntityAttribute(null, 'Toasts', PropertyValueType.COLLECTION_COMPLEX, list);
	return entities;
current output of GET http://<windchill_url>>/Windchill/servlet/odata/v1/ToastsDomain/GetToasts(input='hello',input2='world')
 "@odata.context": "http://<windchill_url>/Windchill/servlet/odata/v1/ToastsDomain/$metadata#Collection(CUSTOM.ToastsDomain.Toast)",
 "value": [
 "key": "msg",
 "value": "hello"
 "key": "msg2",
 "value": "world"
James621-VisitorAuthorAnswer
 "name": "Toast",
 "attributes": [
 "name": "key",
 "type": "String"
 "name": "value",
 "type": "String"
	"imports": [
 "functions": [
 "parameters": [
 "name": "input",
 "type": "String",
 "isNullable": false
 "name": "input2",
 "type": "String",
 "isNullable": false
 "returnType": {
	return entities;
 "value": [
 "key": "msg",
 "value": "hello"
 "key": "msg2",
 "value": "world"
