7-Bedrock
May 28, 2018 12:52 PM UTC
PTC Integrity 11.0 + Direct MKS Java API server access
is it possible to access a PTC Integrity Server / Cloud directly through the JAVA API i.e. via https:// protocol without use of any other local PTC Client installation files? So far, i could not see any information about this in the documentation which is not using command line interface in the end.
Thank you for your support!
API Version of PTC 11.0 - 4.16.506
JRE 8 u172 is used for my own application
fjackschAnswer
7-Bedrock
May 29, 2018 8:44 AM UTC
Well, i think i have to rephrase the question:
What could be the cause for failing to connect to our PTC Integrity Server with our direct access through the API?
This behaviour also leads to two other questions:
Does PTC Server require any specific configuration?
Is a specific Port for the SSL Connection required? If so, which port is it?
The code we used for testing:
public static void main(String[] args) {
        IntegrationPointFactory.enableAPILogging(new File(LOG_FILE));
        IntegrationPointFactory ipf = IntegrationPointFactory.getInstance();
        IntegrationPoint ip = null;
        Session session = null;
        CmdRunner cmdRunner = null;
        try {
            String sessionId = "session0815";
             * secure integration point to server
            ip = ipf.createIntegrationPoint(
                    HOST, PORT, true, APIVersion.API_4_16);
            session = ip.createNamedSession(
                    sessionId, APIVersion.API_4_16, USER, PASSWORD);
            cmdRunner = session.createCmdRunner();
            cmdRunner.setDefaultHostname(HOST);
            cmdRunner.setDefaultPort(PORT);
            cmdRunner.setDefaultUsername(USER);
            cmdRunner.setDefaultPassword(PASSWORD);
            Command cmd = new Command("im", "issues");
            cmd.addOption(new Option("query", QUERY));
            cmd.addOption(new Option("fields", "id,state,type,project,summary,assigned user"));
            Response response = cmdRunner.execute(cmd);
            Result result = response.getResult();
            WorkItemIterator wii = response.getWorkItems();
            WorkItem workItem;
            int id;
            Item stateItem;
            Item typeItem;
            Item projectItem;
            while(wii.hasNext()) {
                workItem = wii.next();
                id = workItem.getField("id").getInteger();
                stateItem = workItem.getField("state").getItem();
                typeItem = workItem.getField("type").getItem();
                projectItem = workItem.getField("project").getItem();
                Project p = new Project (id, stateItem.getId(),
                        typeItem.getId(), projectItem.getId());
                System.out.println(p.toString());
            cmdRunner.release();
            session.release();
            ip.release();
        } catch (APIException apie) {
            apie.printStackTrace();
        } catch (IOException ioe) {
            ioe.printStackTrace();
        } finally {
            try {
                session.release();
                ip.release();
            } catch (Exception e) {
You can find error logs from both hosts attached in this reply. It might help to find a solution.
Thank you in advance!
May 28, 2018 2:05 PM UTC
You can add a boolean to the createIntegrationPoint method to create a secure connection to the Integrity Server. From the API Java Docs for IntegrationPointFactory:
public IntegrationPoint createIntegrationPoint(java.lang.String host,
 int port,
 boolean secure,
 int apiMajorVersion,
 int apiMinorVersion)
 throws APIException
Creates a new IntegrationPoint optionally using a secure communications protocol. Only Integrity Server IntegrationPoints can use secure communication.
Connecting directly to the Integrity Server with the API does not require any PTC IntegrityClient files.
fjacksch7-BedrockAuthorAnswer
7-Bedrock
        try {
            WorkItem workItem;
            int id;
            Item stateItem;
            Item typeItem;
            Item projectItem;
            session.release();
            ip.release();
        } finally {
            try {
                session.release();
                ip.release();
May 29, 2018 7:42 PM UTC
Hello @fjacksch,
In both host1_mksapi.txt and host2_mksapi.txt, you see this:
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
That suggests that the server you're trying to connect to is secure HTTP (https://) rather than clear HTTP.  Based on that, I'd suggest looking at CS138333 - How to use Java API with an SSL enabled Integrity Server.
These other articles might also be relevant:
  • CS141335 - Certificate Error When Connecting Via SSL to a Secure Integrity Server
  • CS187785 - Enabling SSL Logging for the Integrity Client or Server JVM
  • CS223578 - API SSL Communications Fail After Integrity Server Upgrade
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
Integrity Lifecycle Manager
PTC
