8-Gravel
February 23, 2024
Help with worksheet
  • February 23, 2024
  • 1278 views
I am unable to get odesolve working in my worksheet could somebody help?
Odesolve is a numerical method. You have to provide values for the unknown variables A, B, A9, ymax, N, etc, and you have to define the unknown function V6.
EDIT: I just noticed that you seem to ask question  but constantly you don't come back to comment on the answers you got and you don't close your threads. Thats considered really bad manners ... 😞
Some examples:
Scaling factor after conversion - PTC Community
Frame Animation - PTC Community
Matrix - PTC Community
8-Gravel
February 25, 2024
@Werner_E
I am sorry for not responding to the threads was caught up in work and did not knew the procedure. I have corrected my mistake. After adding the values as you suggested it still gives the same error
Function V6(y) is not defined and the variables R1, C1 and B2 are missing, too.
I defined them using some dummy values (all 1) but unfortunately the solve block still throws the very same error message 😞
I don't see whats wrong. Could it be that Prime has found contradictions in the ODE system? Maybe it's worth checking the equation again.
