Seamless PTC Windchill PLM and ERP Integration
- January 11, 2016
- 0 replies
- 1352 views
Having your PLM and ERP systems out of sync can create challenges throughout the inventory and order management process. Learn how KPIT solves the integration challenge by connecting Windchill PLM to ERP. Discover a proven, economical solution that facilitates real-time, bi-directional flow between your Windchill PLM and ERP. Eliminate the uncertainties around data integrity between Windchill PLM and ERP systems. Enable Change Management from Engineering down to Production and Warehousing. Why You Should Attend Learn how manufacturers realize value with iLink. It integrates your two mission critical IT systems, can integrate multiple PLM instances with a single ERP, and drives your total cost of ownership to the lowest levels possible, all while facilitating a seamless, two-way conversation between your ERP and PLM systems.
Learn Top Five Benefits of Seamless Integration .
- No additional hardware or middleware required
- Supports major PLM systems
- Bi-Directional - not just an Item/BOM/Change
- Can integrate multiple PLM instances with a single EBS, JDE, or SAP instance
- Dynamic mapping - interface fields can be edited without changing code.
Presented by: Robert Morrison, KPIT
See all PTC Live Global 2015 - PTC Windchill and PLM Presentations
