Bar chart widget upon Click of a selected bar doesn't pass data to a Popup function
- October 9, 2023
- 1 reply
- 2500 views
In ThingWorx v 9.3.9-b1648, developed a mashup with a bar chart widget to show the data and on-click of a single bar, it should pass the data the Navigation function of popup type. I believe there is a bug with Bar chart widget.
However the bar chart widget doesn't seem to send the selected bar data as a mashup parameter to the Popup function. I've set the 'selectedMode' property to single, also tried with default and multiple modes. Whereas when using the Grid widget, the data is getting passed to the popup function as a mashup parameter.
I've followed the below steps:
- Create a popup mashup and add mashup parameters to it, for binding it in base mashup.
- Create a base mashup, add bar chart widget and configure the widget properties accordingly
- Add data to the bar chart widget. Use a service that returns infotable type result, and the service will have "All data" and "selected row(s)" values.
- In the Base mashup,
- Add Navigation function with Popup type and select popup mashup (created in step-1). Bind the Bar chart widget's Series Clicked event to trigger the navigation function.
- Bind the service's All data to the bar chart widget and configure the widget properties.
- Bind the Service's 'selected row(s)' value to mashup parameter of the Navigation (popup) function
- The Bar chart widget's selectedMode is set to Single. Also tried multiple and default options, didn't work either.
Please let me know if I'm missing something over here!!!
Upon viewing the mashup, the bar chart data gets displayed and the on-click of the bar should open a popup that should carry the selected bar data. However this isn't working in ThingWorx v 9.3.9-b1648.
For ease of reproducing the issue, I'm attaching the entities where I've reproduced the issue, PFA for entities. Import entities in the order of
- data shape (01-DataShapes_chart-selected-data-Values-datashape)
- thing (02-Things_chart-selected-data-Thing)
- popup mashup (03-Mashups_chart-selected-data-popup-mashup)
- mashup (04-Mashups_chart-selected-data-Mashup)
And view 04-Mashups_chart-selected-data-Mashup.xml
