There is a situation, where there is requirement to downgrade the DB to the 8.4 from 9.2. Is there any way to do that ?
@slangley @c_lowy @VladimirN
Shashi
As per the TWX Support, there is no other way to donwgrade, better to keep a backup(dump) of the DB before we upgrade !!
Hi Shashi,
Can the answer in this thread help? Link: https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-Export-Import/m-p/765600
Hi @psp316r ,
It is not possible to downgrade major/minor releases due to architectural/schema differences.
Kindly check the following article:
https://www.ptc.com/en/support/article/CS292279
Bhawna
